ramBunctious 1.6.2J - Japanese Version
Download: http://archive.info-mac.org/disk/rambun ... 162-jp.hqx
This is the Japanese version of the ramBunctious package.
ramBunctious is a blazing fast and feature rich Mac OS RAM disk application.
Its rich set of features lets you customize your RAM disks for your
desired balance of speed, security, safety, and versatility.
* ramBunctious 1.6.2 supports Mac OS 8.6 through Mac OS 9.2. If you need
a version that works on older operating systems (or 68K machines), you
can use ramBunctious 1.5. Contact for the Japanese
version.
- You can have several RAM disks mounted simultaneously, limited only
by memory available.
- ramBunctious has a "write-through" option. When activated, everything
written to the RAM disk is saved to a (real) file. This means that
the next time you mount the RAM disk, all the contents are still
there. This helps protect against data loss in the event of a crash
or power failure.
- ramBunctious uses normal application memory. This means that when
you're done using a RAM disk, that memory is available for other
applications to use. In other words, you don't have to reboot to
reclaim the memory.
- Each RAM disk may be configured to be mounted automatically during
the computer's startup process.
- These options, and more, are fully user-configurable for each RAM
disk via a status/settings window. In addition to the settings, the
status window includes LED-like access indicators that flash when the
RAM disk is being read from or written to.
- ramBunctious is fully AppleScriptable.
ramBunctious 1.6.2 includes several bug fixes:
* Some RAM-only RAM disks would write out large data files to the hard drive.
This was corrected.
* Colored themes are now enabled for RAM disk settings window.
* Fixed conflicts with a couple third party utilities to eliminate cosmetic problems.
* Other miscellaneous cosmetic fixes.
