RAM Disk Backup 3.0
RAM Disk Backup 3.0
Download: http://archive.info-mac.org/disk/ram-disk-backup-30.hqx
Backs up your RAM disk (or any disk) to a location you choose, and restores
that backup to the RAM disk. Run at any time, or put in your Startup and
Shutdown Items folders to automate. Optionally updates the backup
automatically every 15 minutes, or whatever interval you choose. Optionally
includes a temporary folder on the RAM disk which is not backed up, but
created new at every startup. Set the RAM disk window and position of the
temporary folder within it, and have that restored every time.
New in this version:
- Automatically renames your RAM disk
- Optionally makes backups as Stuffit archives
- Keeps any number of previous backups
- Can skip backups, just delete contents and empty trash
- Maintains backup log
- Easy temporary disabling
- Unlimited length of automatic intervals
Free.
Unsolicited comments from users include:
"This thing is great! . . . cool . . . excellent . . . most easy to use . .
. thanks a bunch for writing it . . . a great idea . . . a very handy
applet . . . the scripts all worked flawlessly . . . thanks for a great set
of AppleScripts! . . . very helpful . . . simple and reliable . . .
excellent . . . it's GREAT. I don't know how I lived without it . . .
thanks, John!! . . . thank you very much for your excellent RAM Disk Backup
scripts; they are just GREAT !!! . . . be sure to pick it up
[MacScripter.net] . . . Thanks a lot for your excellent work"
John Rethorst
