QuickInstaller 1.1.0; The Installers Builder.
Download: http://archive.info-mac.org/disk/quick- ... er-110.hqx
QuickInstaller 1.1.0 allows you to create straightforward an installer
for distributing any kind of file. You can build your own 68k, PPC or
FAT installer application in a very simple way, choosing many features
such as: compression, target system, computer restarting, destination
folder. The Built Installer can show your own logo in its main window as
well as a scrolling text in its splash screen. Also QuickInstaller 1.1.0
can build single self-extracting installers and installers having
external documents for distributing your creations by using the media
you want. QuickInstaller 1.1.0 is shareware, it costs less than a small
utility and anyone should afford it. QuickInstaller Maker requires at
least System 7 and a 68030 processor to run. The Built Installer
requires at least System 7 but runs on every processor type. Balloons
are available. The QuickInstaller package contains both 68k and PPC
version.
Why to say more about QuickInstaller 1.1.0? Any technical analysis would be
very prosy: you'd better try it.
Author: Rocco Moliterno
mailto:[email protected]
http://users.iol.it/yellowsoft
New since version 1.0.0:
Added QuickInstaller Maker PPC version.
Added ability to create FAT, PPC and 68k Installers.
Changed compression procedure.
Removed any memory limitation on writing/decompressing.
Removed windows zooming.
Added ability to manage multi-sized text.
Added international support, managing documents name.
Changed window size (Built Installer).
Increased the size of window's logo (Built Installer).
Linked with More Files 1.4.6.
Spin Cursors.
The Built Installer doesn't more remove folders when matches a name
collision but only change theirs contents, saving files out the Installer
subject.
Movable modal dialogs can switch in background (QuickInstaller Maker).
Correct a very little, not-dangerous, bug.
Updated e-mail address.
Minor changes.
