Download: http://archive.info-mac.org/disk/plus-disk.hqx
Requires MacOS 8.1 or later, PowerPC only.
Synopsis:
PlusDisk helps you determine whether converting existing Macintosh disks to
MacOS Extended format would save disk space. MacOS Extended format has the
potential of saving considerable disk space, especially on larger disks
and/or with large numbers of small files. PlusDisk analyzes disk space
usage and recommends a block size which will reduce disk space waste to a
negligible level . It also allows you to choose the block size and erase
the subject disk.
- Board index Classic Info-Mac Info-Mac Archive Disk & File
- Search
- It is currently June 6th, 2026, 11:53 am
- All times are UTC-05:00
PlusDisk
