List Files 2.6J FAT (Japanese version)
Download: http://archive.info-mac.org/disk/list-files-26-jp.hqx
List Files 2.6J is the Japanese version of Alessandro Levi Montalcini's
original.
* List Files is a handy utility that creates a text catalog
of anything you drop on it. You can format the text in many
ways and set up file filters to look for specific files.
You may create different worksets that can be recalled either
from a menu or by holding down some keys when you drop
things on List Files' icon, so you can switch between
cataloging your floppies and searching for big text files
in a flash. List Files can save your catalogs automatically to
different destination folders, so you don't have to save
them manually for every disk or cartridge you want to list.
It can also search entire folders very quickly to find a
specific file inside one of your catalogs, and calculate
checksums and CRC32 values for all of your files. FAT
binary.
WEB MANAGERS NOTE: List Files makes it easy to build lists
of file pointers for use in HTML documents. You can set up a
fully working HTML directory by simply dropping a folder on
List Files' icon.
This is $10 shareware. Have fun and support Alex.
The Japanese versions of Alessandro's programs are available at:
http://persoweb.francenet.fr/~alm/alm_files.html
ftp://ftp.alpcom.it/software/mac/LMontalcini/localized/
Haruka Ishi [email protected] June 14, 1997
