JavaTyper v1.0 - Java and source file type converter
Download: http://archive.info-mac.org/disk/java-typer-10.hqx
JavaTyper modifies the type and creator signature of a file you drag &
drop on it if has a known file name suffix. This allows you to double
click on the file to start the appropriate application.
This is especially handy for Java files, which you can find everywhere on
the Internet and which are not neccessarily MacOS specific (but
nevertheless useful). When you download a Java archive, very often it
consists of several files with different suffixes, sometimes distributed
in several sub folders.
With JavaTyper you can select Alpha, Apple MRJ, BBEdit, CodeWarrior IDE,
Internet Explorer, Metrowerks Java or Netscape as creator for the various
categories (Java files, HTML files, source code files) where appropriate.
JavaTyper walks folders and is freeware.
For more information and download see
http://www.mech.mb.uni-dortmund.de/mech ... Typer.html
Dirk Froehling [email protected]
