IconToPict is a program that lets you see the icons (all the different
types, 'CICN' 'ICL8', 'ICL4', 'ICS8','ICON',...) in a file resource fork,
and save them as PICT, drag on the desktop or copy into clipboard for other
use.
I wrote it 'cause I always needed a fast way to browse them, convert them
and use them some other place.
I include both version PPC and 68K.
