HC Encrypt 1.6
HC Encrypt 1.6
Download: http://archive.info-mac.org/disk/hc-encrypt-16.hqx
HC Encrypt lets you encrypt any file using a key file or an on-the-fly key. You
can use the HCE 2 algorithm if you are a registered user or the older, but just
as secure, HCE algorithm. After encrypting a file, you can scramble it using a
different key and/or compress it. These features, though not available for HCE 2
encryption, provide additional security to the already secure HCE encryption.
Both the HCE and HCE 2 algorithms are freely available to anyone, and a
description of both algorithms are included with the public release of HC
Encrypt.
Common uses for HC Encrypt would be encrypting sensitive documents, files for
transfer over the Net/unsecure networks or other material not suited for the
general public's eyes.
This version of HC Encrypt adds the following
- The HCE 2 algorithm (only available to registered users)
- Serial number schemes and a registration form
- You can now use key files to encrypt/decrypt files
- The interface has changed noticeably
- Many bugs fixed, including one which only occurs when using HC Encrypt with HyperCard Player.
You can read more about the algorithms used by HC Encrypt at
or go to the Yellow Lemon
Software homepage at .
HC Encrypt is shareware $15, £10 or NOK 100, which can be paid by cheque, money
order, bank deposit or cash (Norwegian cash only).
Daniel Stødle
Yellow Lemon Software
