HandyMan 2.0.6
HandyMan 2.0.6
Post by Info-Mac » December 28th, 1999, 11:00 am
Download: http://archive.info-mac.org/disk/handy-man-206.hqx
HandyMan is a complete and easily configurable application dock and launcher
that sits in the Control Strip
It is designed to allow quick and easy access to applications, Control
Panels, Desk Accessories, Folders and other documents stored on your
Macintosh, without having to navigate through several ÒFinder WindowsÓ or
through a multi-layered, hierarchical Apple menu.
It works by clicking on icons installed in the Control Strip window, or
dropping documents onto them. This approach is much handier than aliases
that are on the desktop because the Control Strip window that contain the
icons can never be covered by other windows. HandyMan also requires a lot
less desktop space than the same number of icons on the desktop.
For more info or downloads:
2.0.6 changes:
* Update of Dutch Catalog
* Added Danish catalog.
* command and control key swapped.
* Added Help based on AppleGuide.
* Update of Japanese catalog.
* Added Ukrainian catalog.
* Extensions Strip and Control Strip can run at the same time now.
* Using IconServices when available.
* Translucent Dragging works again in System 9.0.
* Correct detection of system version.
* Dropping an icon on the + that already exists works correct now
* Updating problems fixed with Control Strip 2.0.
* Popinfo should always and faster appear now (Control Strip).
* Both favorites and recent are added to application popup menu's.
* Drag And Drop works for OutLook Express Enclosures (and many others).
* Using Magic Icon Placements (see technote TB 42) for custom sorting.
* Recompile with CW 5 and MacOS9 headers.
* New Register Application Added.
* Corrected email address in documentation.
* New homepage address in documentation and Application.
