Guide Blaster v1.5.1
Download: http://archive.info-mac.org/disk/guide-blaster-151.hqx
Guide Blaster is a utility application which deletes all the Apple Guides
from your startup volume or lets you move them to another folder you
specify.
How do I use it?
To use Guide Blaster, double-click it from the Finder. Select either
"Blast All Guide Files" or "Move All Guide Files" from the File menu. If
you select "Blast All Guide Files", all Guide files will be deleted from
your startup drive. If you select "Move All Guide Files", you will be
prompted for a folder to move the Guide files to. To delete or move Guide
files from another drive, startup from that drive.
How much is it?
Guide Blaster is free and you can freely distribute it as long as this
document accompanies it and you do not sell it or include it in any product
that you charge for. IF YOU WOULD LIKE TO INCLUDE GUIDE BLASTER IN YOUR
PRODUCT, THE ONE-TIME, PER-PRODUCT LICENSING FEE IS $100. PLEASE WRITE OR
SEND EMAIL TO THE ADDRESS AT THE END OF THIS READ ME DOCUMENT FOR
INFORMATION ON OBTAINING A LICENSE.
Guide Blaster if a Fat Binary and so runs native on PowerMacs as well as
on 68K Macs.
Changes in version 1.5.1:
* Added the ability to move Guide files as well as delete them.
Changes in version 1.0.1:
* Fixed a bug that prevented Mix-In Guide types from being deleted.
Please send any problems, bugs, or suggestions to:
Alamo Computer
P.O. Box 610217
San Jose, CA 95161-0217
Email: [email protected]
