Cat o¹ Seven Tails is System 7 or above ONLY. Its only interface is
Drag and Drop, so you cannot use it with earlier Systems. If you
double-click on it from a System 6 machine, you will get an error
message and the software will quit gracefully.
To use Cat o¹ Seven Tails _with_ System 7 or above, simply select
the files you want to concatenate and drag them on the program's
icon or an alias of it. A new file called "Concatenated filesŠ" will
be created, and your original source files will remain unaltered.
