Grapple 1.3
Grapple 1.3
Download: http://archive.info-mac.org/disk/grapple-13.hqx
Grapple 1.3 - A Fast and Powerful String Finder for the Mac!
Grapple is a string finder for the Mac that is very fast, powerful
and friendly. Version 1.3 is faster than any other string finder we
could find. Whether you've lost a piece of email, a business letter or
a C/C++ header file Grapple will quickly find it!
Grapple has a clear and intuitive interface. Set up a string to find,
choose where to start your search and hit the search button. Grapple
searches recursively through the folder hierarchy for files of the chosen
type (or types) which contain your string. Matched strings are extracted
and listed in a window for you to browse through. At the end of a search,
select any file from those listed and either view it from within Grapple,
have the Finder display its location or open it with the editor of your
choice - all at the press of a button!
Grapple has many features not mentioned here but those that are
NEW to version 1.3 include:
- now faster than any other string finder tested!
(check out the test results at the web site).
- export search results as a plain text file
- PC and UNIX files are indexed and viewed correctly - as for Mac files
- numerous user interface tweaks.
Grapple is fully functional SHAREWARE.
See the PlaNet-3 Software web-site for more details:
http://www.california.com/~rharmon
Requirements.
Grapple requires System 7 or later with 500K of free memory.
Best Regards
Robin Harmon
