Grag Bag 2.5.2 simple file organization
Download: http://archive.info-mac.org/disk/grab-bag-252.hqx
What's it for?
Grab Bag was created to make it easy to access a bunch of files from one
location and to allow flexible organization of your files. Ever find
yourself digging through layers of folders to get to applications or
documents you need for a current project, then doing it all over again
the next time you work on the project? Ever wish you had an easy and
flexible way of grouping files? Maybe you want to pull together several
files from different folders on your computer just for awhile but you
want to leave the originals where they are. Maybe you want to organize a
bunch of your files in several different ways. These situations and many
others can be easily and quickly handled by Grab Bag without any of the
usual window-clutter.
System Requirements:
PowerPC processor for PPC version (68K version available - just email me)
AppleScriptn installed
System 7.5 or later
