Download: http://archive.info-mac.org/disk/go-get-it.hqx
GoGetIt is a utility that simplifies the process of getting and opening
applications, files, folders, URLs, mailto:'s, etc. by generating customizable
aliases/bookmarks. Just type a couple of letters and Go.
Requires System 7.1 or above with at least 1.7 MB of RAM.
- Board index Classic Info-Mac Info-Mac Archive Disk & File
- Search
- It is currently June 7th, 2026, 9:41 pm
- All times are UTC-05:00
Go Get It
