Folders Checker 1.1.0
Download: http://archive.info-mac.org/disk/folders-checker-11.hqx
Folders Checker 1.1.0 will help you organize and control the large number of
files that tend to "grow" inside any folder of your hard disks. How many
times, after trying a CD full of Shareware (such as those that are included
with magazines), you found the Preferences folder increasingly full of new
preferences ? So, I felt the need for a program that would keep track of my
growing Preferences folder as well as all of my other folders.
With this new version you can handle invisible files too !
On-line registration with secure server is possible.
You can't miss this program !!
Fully MacOS 8.x compatible. Works with System 7.x with Apparence Manager.
FAT, Shareware.
