Flush It! 2.0.2
Flush It! 2.0.2
Download: http://archive.info-mac.org/disk/flush-it-202.hqx
This is version 2.0.2 of Flush It!, a small disk cache management utility
application that allows you to control when and how often your RAM-based
disk cache gets written out to disk.
This version fixes a bug in the settings code which prevented time
intervals selected from the popup menu by mouse from activating the
"Apply" button. Also changed was initialization code that threw systems
incompatible with Flush It! into the debugger. Added a feature where, if
the "Hide settings in background" is selected, Flush It! will launch with
the settings window open.
The technical basis for the application, operating instructions, and
shareware information are all contained in the included Read Me file.
Flush It! 2.0.2 is $3.00 US shareware with a thirty-day free evaluation
period.
Many thanks,
Jack Browning
Dr. Benway .................... Interzone
