Download: http://archive.info-mac.org/disk/find-in-files-21.hqx
Find In Files searches a set of files (or all files) for some text.
Why would you use Find In Files? Here's an example: Suppose you have a
bunch of HTML documents, and one or more of them has some information you
need. You could open every one of the files and search them by hand, or
use Find In Files to search for you. Simply enter some key words in the
"Search For" text area, optionally enter the file search type, select the
folder where the search begins, and click on Search. Find In Files returns
with a list of files that contain the text, along with a text snippet.
Find In Files is a fat-binary application. $10 shareware.
M A U I S O F T W A R E
Aptos, CA 95003
phone/fax: 1-831-689-9314
http://www.mauisoftware.com/
email: [email protected]
