Find File 1.1.3 patch
Download: http://archive.info-mac.org/disk/find-f ... -patch.hqx
About Find File 1.1.3 patch :
A neat feature in Find File 1.1.3 is the option to automatically close Find File
when you select a menu item (or double-click on a found item) while holding down
the option key. Unfortunately, this doesn't work with keyboard equivalents. For
instance, command-option-o doesn't do anything. This patch modifies Find File
1.1.3 to enable the use of the option key with keyboard equivalents. After
applying the patch, you'll find that command-option-o opens the selected items
and quits Find File.
Also, the OFind File ShortcutsEO dialog, available under the Guide menu, states
that OYou can quit Find File by pressing the Option key while you click any Find
File windowOs close box. O Nice, but it doesn't work ! This patch will also fix
this bug.
This patch is designed for Find File 1.1.3 only (part of MacOS 7.6). It should
work with localized verion, but comes without any warranty. Use it at your own
risks !
Enjoy !
Patrick Stadelmann
