Download: http://archive.info-mac.org/disk/file-typer-531.hqx
FileTyper is a popular and powerful shareware type/creator and file
attribute editor, including batch and filtering capabilities and a very
fast file manipulation engine. It also includes MakeAutoTyper, a utility
that creates the widely-used "AutoTyper" utilities, and FileTyper Menu,
which gives you fast access to FileTyper's functions from a Finder menu
item and command key shortcut.
Version 5.3.1 is a minor bug-fix update that removes the expiration date
inadvertantly left in FileTyper Menu.
More information can be found on the FileTyper home page:
http://www.ugcs.caltech.edu/~dazuma/filetyper/
The author, Daniel Azuma, can be contacted at
mailto:[email protected]
