FileT&C 2.1.0; type & creator changing.
Download: http://archive.info-mac.org/disk/file-tc-210.hqx
FileT&C is an useful application for changing file type and/or creatorŠ
It's very useful for normal desktop usage, but is really cool when works,
fine, fast and in background, with a lot of files. Also it can scan,
quickly, disks and folders looking for files to treat...
FileT&C is Internet Config aware and has a couple of options to change,
according to name extension, following the Internet Config's File Mapping
setting.
FileT&C has some useful hot keys for changing, on the fly skipping the
"Request Dialog", by using the preferred type and/or creator set in the
preferences. You can also instruct it to ignore during its performance,
some kind of files or to treat only some other specific types.
FileT&C is Macintosh Drag and Drop aware and requires at least System 7 to run.
The FileT&C 2.1.0 package contains both 68K and PowerPc versions.
Author: Rocco Moliterno
mailto:[email protected]
http://users.iol.it/yellowsoft
New since version 2.0.2:
Added ability to use menus. Drag Manager support. Added ability to treat
only some kind of files. Movable modal dialogs can switch in background.
Added "Internet" menu. Added ability to use Internet Config's File Mapping.
Added don't change check boxes so, if you forget to use Hot Keys, you've
one more change for leaving untouched type or creator. Added 'aete'
resource. FileT&C always check for file to skip/treat, before working.
Removed windows zooming. Removed the annoying alert occurring at startup,
when a preference file doesn't exists. Slightly changed desktop icon.
Revisited and improved the whole code. Linked with MoreFiles 1.4.6. Updated
e-mail address. Changed web page address. Minor changes.
