Eject = Unmount (FR)
Download: http://archive.info-mac.org/disk/eject-unmount-fr.hqx
eject_equ_unmount.sit.hqx - Eject = Unmount - INIT
Is a system extension which allows you to unmount disks when they are
ejected.
eject_equ_unmount.fr.sit.hqx - Éjecter = Démonter - INIT
It is the same version as eject_equ_unmount.sit.hqx, but this one is in
french.
Firewalker
http://wwwperso.hol.fr/~callene/
