Download: http://archive.info-mac.org/disk/duplimizer-241.hqx
DupliMizer 2.4.1
What it is: AppleScript program that duplicates and optimizes your entire
web folder in one pass.
Author: Ton Brand
Company: Tonbrand Software
License: Shareware US$6
Computer: any Mac
Mac OS: 7.6 or higher (not OSX)
Required: Scripting Addition (osax) "ACME Script Widgets"
Abstract:
DupliMizer is an AppleScript program that duplicates and optimizes your
entire web folder.
Simply drag your Web Folder to the program's icon and all web pages are
optimized in one pass! There is a limit to the hierarchical depth that
DupliMizer can handle: Eight levels must be sufficient in practically all
cases. A detailed log is available.
DupliMizer requires the Scripting Addition (osax) ACME Script Widgets
(single CPU). For Mac OS 7.6 to 8.1 you need the (old) version 2.5.2 and for
Mac OS 8.6 or later you can use the current version which is 3.0. The osax
is shareware by Acme Technologies, see www.acmetech.com.
Version 2.4.1 fixes some errors under Mac OS 7.6.x.
