DSL10.hqx
DSL10.hqx
Download: http://archive.info-mac.org/disk/doublet-scan-lite.hqx
Find all duplicate files on your hard disks.
Doublet Scan Lite is a fast way to find all the duplicates,
empty folders and unique files on your hard disks.
It's very easy to use: load the directory of your hard disks and scan
for the duplicate files... after these two easy steps, you 'll be
able to select all the duplicate files you want to eliminate and
move them to the trash...
Localizations available at: http://www.hyperbolicsoftware.com/download.html
Japanese
French
Download page: http://www.hyperbolicsoftware.com/download.html
Direct links:
http://www.hyperbolicsoftware.com/progr ... canL10.sit
http://www2.pinkpig.com/giunto/DoubletScanL10.sit
ftp://ftp.hyperbolicsoftware.com/DoubletScanL10.sit
