DiskCatalogMaker 2.5.1 pt_BR
Download: http://archive.info-mac.org/disk/disk-c ... 251-br.hqx
DiskCatalogMaker 2.5.1 [pt_BR] (A Disk Management Tool)
Brazilian-Portuguese version - translated by Marco Andrei Kichalowsky.
DiskCatalogMaker is a simple disk management tool which catalogs disks.
FEATURES
- Finder7.x-like look and feel.
- Supports Finder AppleEvents. (Select original, and open original)
- Supports drag and drop. (Copy, clip, trash, and catalog disks.)
- Supports StuffIt / CompactPro / LHA archive Formats.
- Mac OS Classic versions is a FAT application (includes PowerPC and 68K
code).
DiskCatalogMaker requires MacOS/System 7.0 or later.
