Download: http://archive.info-mac.org/disk/dcscripts-211.hqx
size of the file : 300 KB
target platform : Macintosh (only)
Short: These scripts provide access the hidden features of Apple's Disk Copy disk image utility.
multi-line description :
SegmentSMIer can instruct Disk Copy to :
segment images into your chosen number of parts; segment images into 1.4 MB floppy disk sized parts, for floppy archiving an image; make a NDIF disk image or first segment into a self-mounting image or ÔSMIÕ.
DropMakeSMI will instruct Disk Copy to create a self-mounting image of any NDIF image dropped onto it on the desktop of your startup disk. Not as flexible as SegmentSMIer, but speedier and just as robust.
NDIF Converter will quicken the process of converting old Disk Copy 4.2 images to the compressed NDIF format.
ImageCheck will induce Disk Copy to run a special internal check sequence on any disk image dropped onto it and inform you if it found a problem.
Floppy Archiver allows you to have a compressed NDIF image to be made instantaneously on the desktop of your startup disk from the 1.4 MB floppy disk you just dragged onto it. Speeds up archiving of floppy disks to some other media.
Main features :
New easy-to-use button-oriented interface;
Data entry verification;
Ability to make images Self-Mounting, i.e. images independent of Disk Copy;
Ability to choose where you want the output files to go;
Correct handling of all cancellations;
Supports Disk Copy 6.4;
Read Me in PDF format.
System requirements :
For best results work with Disk Copy version 6.3.3 or later.Ê Mac OS 8.1 (or later) and Disk Copy 6.3.x are required for creating self-mounting images.
where file should be placed : info-mac/_Disk_%26_File/
