Download: http://archive.info-mac.org/disk/data-rescue-211-jp.hqx
Note:
1) This is the Japanese version. An english version was posted as
"data-rescue-211.sit"
2) 68K version - a FAT version is also posted.
Data Rescue is a tool for recovering lost Macintosh volumes. It recovers files
and folders from crashed hard disks, floppy disks, or removable cartridges.
Recovered data are saved to another medium, leaving the original disk untouched.
The main interest in Data Rescue is that the strategy for finding lost files is
original, different from the strategies used by other tools like 'Norton
Utilities'. Not only will it find your data in situations where the other tools
fail, but it will recover them in a much better condition, restoring icons, dates
and even folder hierarchy. The shareware fee for Data Rescue is $39. Until you
register your copy with a personnal code, you can only recover 1 file per
session. This allows you to test Data Rescue and check that it helps you in your
particular situation. Works on all Macs, needs System 7 or better. Compatible
with MacOS 8.5 and HFS+. Can be distributed freely for non-profit purposes in the
form of this archive. Documentation included, updates at
