data-rescue-211-fat.sit (a data recovery tool for crashed volum
Download: http://archive.info-mac.org/disk/data-r ... 11-fat.hqx
Note:
1) FAT version - a 68K version is also posted.
2) Version 2.1.1 replaces version 2.0.2. It handles Japanese and other
non-Roman scripts. Bugs were fixed and new features were added.
Data Rescue is a tool for recovering lost Macintosh volumes. It recovers
files and folders
from crashed hard disks, floppy disks, or removable cartridges. Recovered
data are saved to
another medium, leaving the original disk untouched.
The main interest in Data Rescue is that the strategy for finding lost
files is original,
different from the strategies used by other tools like 'Norton
Utilities'. Not only will it
find your data in situations where the other tools fail, but it will
recover them in a much
better condition, restoring icons, dates and even folder hierarchy.
The shareware fee for Data Rescue is $39. Until you register your copy
with a personnal code,
you can only recover 1 file per session. This allows you to test Data
Rescue and check that it
helps you in your particular situation.
Works on all Macs, needs System 7 or better. Compatible with MacOS 8.5
and HFS+.
Can be distributed freely for non-profit purposes in the form of this
archive.
Documentation included, updates at
