Creator Changer is an application which allows you to edit creator and
file types of files. There is an editable automatic change feature, an
editable preferred types list, and the dialog boxes support Macintosh
Drag and Drop. This version is compatible with MacOS 8. Source code is
included for Symantec and CodeWarrior.
