Change UU 1.0 AS
Change UU 1.0 AS
Download: http://archive.info-mac.org/disk/change-uu-10.hqx
This simple script will change the names of all your UUencoded text files
contained in the chosen folder.
It will change from the names given by UUCD (e.g. ) to names
compatible with Wincode (e.g. ).
Useful if you want to pass long files on several floppies to a Windows user, and
you have to rename them all. OK, there may be other ways to do it, but here's
one. :)
There is no help or warning message (although only "TEXT" files with ".uu." in
their name are affected), so please experiment with a disposable folder first.
The script needs the following additions in order to run:
- Choose Files/Folders
- String commands
Improvements and comments on the script are welcome.
Giovanni Giusti
