CD-Namer 2.0.9
CD-Namer 2.0.9
Download: http://archive.info-mac.org/disk/cd-namer-209.hqx
Sent: 16 October 1996
With CD-Namer v.2.0.9 you can edit the entries of your Audio CDs of the
program AppleCD-Audio which is part of the system 7.0. You can also
import and export entries from other CD databases.
Christoph Schaffhauser Tel: +41 (0)61 751 23 42
DarkEagle Software EMail: [email protected]
http://www.datacomm.ch/darkeagl/
