CatFinder is a powerful disk management tool that catalogs your disks and
provides an intuitive Finder-like interface for browsing the catalogs.
Floppies, hard disks, CD ROMs, any disk can be cataloged. Once a disk is
cataloged you can quickly and easily browse it's contents without having the
disk mounted. CatFinder also offers powerful find and report features that
will help you find and organize your files.
Version 2.1.5 corrects problems locating the catalog folder and other bug
fixes.
