Catalogue
Catalogue
Download: http://archive.info-mac.org/disk/catalogue-3b3.hqx
Catalogue is a 20 $ disk utility that keeps track of all your removable
media. You can then easily find any document or application. Here are
some of Catalogue's advanced features:
- Scan the contents of StuffIt and Compact Pro archives.
- You can choose the name Catalogue uses to save a volume. This lets you
save several read-only volume having the same name.
- It implements a powerful and fast search function.
- You can search for duplicates in one or several volumes.
- Launch applications and open documents directly from within Catalogue's
main window even if the file belongs to a Stuffit archive.
- Automatically scan inserted disks or mounted volumes when Catalogue is
active, unless this feature is bypassed.
- Create as many folders to store as many different catalogs as you want.
- Create very compact archive files, up to 40 % smaller.
Catalogue requires MacOS 7 or later.
You can find additional information on http://catalogue.home.ml.org or by
dropping me line to [email protected]
