Download: http://archive.info-mac.org/disk/catalo ... -fm-38.hqx
This FileMaker 4 (easily converted to FileMaker 5) database provides
drag and drop indexing of disks and folders. It gathers information
about each file, such as path, name, size, dates, type, creator etc.,
during indexing. Plus, it has the speed and power of a relational db.
Duplicate files can be determined almost instantly based on three
separate criteria (name, size and modification date).
The database is freeware, and has no locked layouts or password
protection. Modify it as you see fit. Needs Jon's Commands free
OSAX - see read me.
Version 3.8 fixes an error handling bug that was partly fixed (and
partly broken) in version 3.7.
A version that's compatible with the date settings of most European
systems is available by email request, or available soon on my web
site at: http://www.musselrock.com/fm_waldos.html
