C&T Changer 2.0
C&T Changer 2.0
Download: http://archive.info-mac.org/disk/c-t-changer-20.hqx
Sent: 11/8/97 5:16 PM
Received: 11/8/97 6:06 PM
To: [email protected]
Enclosure: C&T Changer 2.0.sit
C&T Changer is an Apple Script Droplet to change creator type and file type
of a file. I made this script to deal with many files all at once or change
to same file type and crator frequently, which is made by C&T Changer
Maker.
If some document files are droped to the C&T changer or you select some
document files and launch the C&T Changer from Apple menu, the crator and
the file type of the document files will be changed.
Requirements:
You need Apple Script.
You must install OSAX "Dialog Director" and OSAX "Resource Utilities" which
is included in the package of "Dialog direcor v0.6"
Tetsurou Kurita
