BetaScan is a neat Drag 'n Drop utility which scans files, folders and
disks for none final code files.
None final code file, means any program or system extension (control
panels, drivers, libraries,etc..) that aren't 'final' versions. These none
final versions can be the reason of big system crashes when they are system
extensions. Size : 36kb.
