Download: http://archive.info-mac.org/disk/ascii-converter.hqx
ASCII converter - is a simple "drag and drop" application that converts text files from Windows to Macintosh. MacOS and Windows use two different ASCII tables (a way to represent the characters) so when you open a Windows text file with a Mac application all the characters like: è,à,é,ù,ì,ò etc. are misinterpreted. ASCII converter fixs this drawback and enable you to correctly read the text file. To convert a file, drag it over the ASCII converter icon until highlighted and release the mouse button. ASCII converter will create a new text file in the same directory of the original file.
