Apple HD SC Setup 7.3.5 Patch R2
Download: http://archive.info-mac.org/disk/apple- ... -patch.hqx
I received many reports that my previous patch did not work, here is a new
patch that should work if it is used only on the HD SC Setup 7.3.5 that is
gotten from
, or other Apple
Software Updates sites, a list of which is at
---begin previous abstract---
This is a patch for Apple HD SC Setup 7.5.3 that allows it to recognize
non-Apple drives. I threw it together in about 5 minutes using ResEdit,
ResCompare, and info from
This patch may be distributed on the info-mac CD-ROM.
-----end previous abstract---
This time I tested the patch, and it works, but it is only guaranteed to
work with the version from the above location(and even the I can't
guarantee that the patched version of HD SC Setup will work as advertised).
You should not expect Apple to support this modified version of HD SC Setup.
Joel Klecker
Maintainer of the comp.sys.mac.comm FAQ (updated version coming soon)
"There are three kinds of lies: lies, damned lies, and statistics."
-- Benjamin Disraeli
