marker-control.sit.hqx
Post by Info-Mac » November 23rd, 1992, 11:00 am
Download: http://archive.info-mac.org/dev/sym/thi ... ol-06b.hqx
This is a new version of Marker Control, a control panel that causes
files in THINK C to be marked and their window positions saved.
NEW VERSION v0.6b
% Fixed a bug where if you had the "Only Mark Files Newer Than:"
option OFF and moved a window without making any changes to it,
it set the modified date of the associated file to some time
in the early 1900s.
% Made it so that window positions and sizes are saved even if
you close the windows with "Close All" or by quitting THINK C.
Before, they were only saved if you actually used "Close" from
the File menu.
% Now functions that contain function prototypes as parameters are
marked.
Executive Summary
% Save window positions in THINK C.
% Mark functions in source files.
% Drop RMarker ControlS onto your System Folder and restart.
Open the RMarker ControlS control panel to configure its operation.
% Run THINK C and notice the difference.
- Window positions are saved (open a file, move its window,
close it, reopen it to try this out)
- Command-click on the title bar of source file windows to
see a list of the functions in that file.
Brought to you by Troy Anderson
