WDEF PAtch from apple
Post by Info-Mac » June 21st, 1992, 9:00 am
Download: http://archive.info-mac.org/dev/src/wdef-patch-21-c.hqx
Hi, netters
WDEFPatch is an Apple sample code snippet that shows how to
add in a clean way a new behaviour to an existing WDEF. It adds
a new part in the window title bar that, when clicked, is reported
to the application. I implemented the tracking of that part.
In case you downloaded the improved WDEFPatch (originally from
Steve Falkenburg), in the meantime I discovered a funny quirk
in the system software WDEF. (at least, sys 7's). I found it
when adding a zoom box to the window. Falkenburg's had not, neither
did my original improvement. It can only be the system's misbehaviour
but luckily a workaround could be found very easily (and is clean).
I included the two apps. The one without workaround and one with it.
Read the source for details. Then laugh when you see what happens.
I feel my new knowledge can be useful also to others.
Enclosed is a binhexed-compactpro archive.
Roberto Avanzi.
