dev - TurboTCP update (again)
Download: http://archive.info-mac.org/dev/src/tur ... 01-cpp.hqx
--========================_13678449==_
Attached is a copy of TurboTCP 2.0.1. This should be placed in a
development libraries directory and replace any previous version of
TurboTCP. This version fixes a minor compile-time error with 2.0.
-eric
Description:
The TurboTCP class library integrates the Think Class Library with Apple's
MacTCP driver. This library provides robust support for most TCP/IP
applications on the Macintosh. Its major features include: asynchronous
operation (TurboTCP does not use "polling loops"), high-speed automatic
data receiving mechanism, mix-in architecture, robust error recovery, and
background friendly.
Content-Type: application/mac-binhex40; name="TurboTCP_2.0.1.sit"
Content-Disposition: attachment; filename="TurboTCP_2.0.1.sit"
