3pointplotters-c
3pointplotters-c
Download: http://archive.info-mac.org/dev/src/thr ... ters-c.hqx
Hello, there, MacGift Givers!
This file contains 3 Think C 5 projects.
1 "NewCube" which puts up a data window and a drawing window, then uses
point plots to draw an anitmated cube which rotates on two axis'. It's
an update from an old .c file I found on the old BMUG BBS.
2 "NuCube" is a variation on the other done by Mark Hanrek, which adds a
more sophisticated Mac shell and includes a GWorld.
3 "NewShuttleViewer" is a Pascal to C port I did of "Eddy's Shuttle
Viewer, and improved upon it slightly. The original and .p file is
included. There's also a code fragment that can be added to draw the
coordinates where the points result over the window repeatedly as they
are generated. The program draws a wire-frame Space Shuttle, ala point
plots, then erases, then draws a slightly rotated view, repeat ad infinity.
-Ken-
----------------------Get to snippin'!------------------------------------
