source/pascal/tcpexample.hqx
Download: http://archive.info-mac.org/dev/src/tcp ... le-pas.hqx
This is some example code to demonstrate the use of my TCP unis.
These units implement a relatively high level interface to MacTCP,
and allow fairly easy writing of TCP applications in Pascal using
event driven programming. The example program is not a full shell,
it simply implements a very basic finger to a fixed user@host.
It should be fairly easy to understand. I've used the code in many
apps, most of which are available from various ftp sites, or from
redback.cs.uwa.edu.au in /others/peterlewis.
Hope its useful to someone,
Peter.
TCPExample v1.0.0 Copyright 1992 Peter N Lewis
