Spinning Cursor Library (code)
Post by Info-Mac » February 5th, 1993, 11:00 am
Download: http://archive.info-mac.org/dev/src/spi ... rsor-c.hqx
This posting contains a library file that allows any
program (C, Pascal, Fortran) to install an asynchronous
(task-independent) spinning cursor.
It is blatantly copied from the book "Macintosh Programming
Secrets, 2nd Edition", and distributed with the author's
consent. All I did (!) is type the code. I can also tell you
that it works fine ;-).
Instructions, source code (Think C) and sample code (Pascal
and C) are included. If you have questions, feel free to ask!
Philippe Casgrain
P.S. This is postcard-ware: it is not my intellectual property,
but if I stick the disk on my fridge, my kids don't see the
point... :-)
