RegisterSafeFat.cpt.hqx
Download: http://archive.info-mac.org/dev/src/reg ... gles-c.hqx
This is C source code for breaking down a region into
rectangles, plus notes and a sample program to
demonstrate it in action.
Comments welcome: send to [email protected]
------------Cut here-----------------
Attached is the Rez source for a template, similar to the 'sdes'
template, which allows the construction of safe, fat code resoruces with
register-based calling conventions.
Moderators:
This probably belongs in dev/src.
Feel free to include this on any CD you see fit.
--Chris
Chris Larson -- Amateur Macintosh Geek, CoBase Research Assistant
Internet: [email protected] | Insert Disclaimer Here
