PictTool
PictTool
Download: http://archive.info-mac.org/dev/src/picttool.hqx
This was made from necessity for a project I was working on.
It is provided "AS IS". I will not make any changes or modifications.
It allows you to "Dump" the contents of 'PICT' files into a human
readable form. I needed it to decipher PICT Comments. I hope it helps
you. There used to be a utility called PICTDetective. If I could have
found it, I wound not have created this.
Run the application, choose a PICT file, and wait. It will dump the file
to the screen and to FILENAME.dump. The dump file will be of type text.
This is shareware. If it is useful, please E-Mail me. If not, don't
bother. If it is really useful, send lots of money...
Thanx,
Greg Ames
