OTCFM68KGlue abstract
Download: http://archive.info-mac.org/dev/src/otcfm-68k-glue.hqx
OTCFM68KGlue is a library/code resource combination that allows
applications or shared libraries executing in the CFM68K runtime
environment to call Open Transport. It is designed for projects
with the following requirements:
- The project calls Open Transport.
- The project is a shared library or an application that uses
shared libraries, or must otherwise take advantage of the
CFM runtime environment.
- The project requires 68K support.
- The project must run under versions of MacOS prior to 8.1.
The library is designed for application-level code (i.e.,
applications or shared libraries). Also, note that it requires
minor source code changes.
Full source is included.
