MoreFiles 1.4.3
MoreFiles 1.4.3
Post by Info-Mac » September 12th, 1996, 9:00 am
Download: http://archive.info-mac.org/dev/src/more-files-143.hqx
MoreFiles is a collection of high-level routines written over the last couple
of years to answer File Manager questions developers have sent to Apple
Developer Technical Support.
The routines have been tested (but not stress-tested), documented, and
code-reviewed by Apple's Developer Technical Support. This release fixes
several minor bugs.
MoreFiles provides: high-level and FSSpec style routines for parameter-block
only File Manager calls; useful utility routines that perform many common
File Manager related operations; a robust file copy routine; a recursive
directory copy routine; a catalog searching routines; high-level and FSSpec
style routines for Desktop Manager calls; routines for dealing with
pathnames; and a flexible directory iteration (scan) function.
