Headlines 1.0.1 code
Download: http://archive.info-mac.org/dev/src/headlines-101-c.hqx
This is the source code for the After Dark module "Headlines,"
version 1.0.1.
I don't know whether it's legal to redistribute two of the source files
I used. For that reason, I've not removed the object code for those
files, and have included only their header files. They are
ATMInterface.c and NeoTextBox.c. If anyone can advise me about the
legality of distributing these sources, I'd like to hear from them.
In any event, you'll probably need to keep the project file and not
"Remove Objects" if you want to successfully compile Headlines.
Note that this submission does not include the code to Greg Smith's
"spew," which was the basis for Headlines. This is only because Greg's
distribution terms precluded putting this on e.g. Pacific HiTech's
Info-Mac CD-ROM. My own terms, now, are a little looser.
I ftp'd the source to "spew" from wuarchive.wustl.edu, in
/usenet/comp.sources.games/volume01, where it probably still is.
Jamie McCarthy Internet: [email protected] AppleLink: j.mccarthy
