eclectic CDEF Collection 1.0
Download: http://archive.info-mac.org/dev/src/ecl ... ection.hqx
The eclectic CDEF Collection is a set of 2 freeware CDEFs (control
definition functions) written in Pascal, the Celsius CDEF and the Gauss
CDEF.
CDEF stands for "control definition function": it is a way to define the
appearance and the behavior of custom controls. Custom controls may be
dials, gauges, sliders, and so on. CDEFs may be used by almost every
Macintosh software and by practically every development environment and
programming language.
The Celsius CDEF implements a thermometer- or barber pole-style progress
bar similar to that used by the Finder in the Copy or Find windows.
Additional options allows you to honor custom colors stored in 'cctb'
resources, to draw the bar always in the active look ignoring
deactivations, and finally to display the bar with a 3D-like "inset"
effect, as shown in the develop 15 article "Working in the Third
Dimension".
The Gauss CDEF draws application-specified blocks of text. It can draw
simply the control's title, append a numeric value to it or draw a block
of text up to 32K set up by the calling application. Optionally the
Gauss CDEF can also honor 'cctb' resources, draw the text with the
owning windows' text font, size and style, and draw a 3D-like effect
(inset or raised).
The eclectic CDEF Collection consists of
- two CDEFs: the Celsius CDEF and the Gauss CDEF - two 'stubs' to allow
source-level debugging of the CDEFs: StubCDEF and JumpCDEF - some
utility routines - a demonstration application for the CDEFs
The eclectic CDEF Collection is written by:
Sebastiano Pilla Viale dei Mille 20 31100 Treviso (Italy)
