E-Z Progress Bar 1.0a.sit.hqx
Download: http://archive.info-mac.org/dev/src/e-z ... r-10-c.hqx
--========================_6835356==_
Content-Type: multipart/header-set; boundary="========================_6835356==_D"
--========================_6835356==_D
Content-Transfer-Encoding: base64
Content-Type: application/applefile; name="%E-Z_Progress_Bar_1.0a.sit.hqx"
Content-Disposition: attachment; filename="%E-Z_Progress_Bar_1.0a.sit.hqx"
AAUWBwACAAAAAAAAAAAAAAAAAAAAAAAAAAIAAAADAAAAMgAAAB0AAAAJAAAATwAAACBF
LVogUHJvZ3Jlc3MgQmFyIDEuMGEuc2l0LmhxeFRFWFRCTkhRAQABPgAAAAAAAAAAAAAA
AAAAAAAAAAAA
Content-Type: text/plain; name="E-Z_Progress_Bar_1.0a.sit.hqx"; charset="us-ascii"
Content-Disposition: attachment; filename="E-Z_Progress_Bar_1.0a.sit.hqx"
Enclosed is a submission for the source code folder of Mac development
(This archive can be included in CD ROMs)
E-Z Progress Bar is a progress bar class which creates and maintains a progress
bar window. All you have to do is show it and update its value. It is also
customizable, allowing for flexibility in appearance and use. A demo app shows
how to use it. Also included is ChiselClass, a class which will create subtle
3-D chiseled effects on rectangular objects. All code is freeware.
